Webcast-Catalyst9k
two aux connected by modem problem
modem can accept the call,but can't ping each other
seems ppp not established
and after a while disconnect
%LINK-5-CHANGED: Interface Async65, changed state to reset
debug ppp negotiation and debug ppp packet show nothing
the related config:
interface Async65
no ip address
dialer in-band
dialer pool-member 1
async default routing
async mode interactive
interface Dialer1
encapsulation ppp
dialer pool 1
dialer string xxxxxxxx
dialer-group 1
line aux 0
no exec
modem InOut
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
autoselect timeout 120
stopbits 1
speed 115200
flowcontrol hardware
Re: two aux connected by modem problem
If your not showing any PPP debug information at all you may need to enable local authentication on your routers. A sample of the basic AAA commands are:
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default local
A sample config for setting this up is at:
http://www.cisco.com/en/US/tech/tk13/tk36/technologies_configuration_example09186a0080093d2b.shtml
Hope it helps.
Bob
If this router is accepting the call, not sure about the reason for Async interface tied to dialer interface using dialer profile..Pl. remove the interface dialer 1 by using follwing command
conf t
no int dialer1
int async65
no dialer pool-member 1
Now configure the interface async65 for following
interface Async65
dialer in-band
encapsulation ppp
dialer-group 1
After the turn on following debug
debug modem
debug ppp nego
debug ppp authentication
problem still exist
the lcp can not get established
00:07:18: As65 LCP: O CONFREQ [REQsent] id 2 len 20
00:07:18: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
00:07:18: As65 LCP: MagicNumber 0x0251D9FF (0x05060251D9FF)
00:07:18: As65 LCP: PFC (0x0702)
00:07:18: As65 LCP: ACFC (0x0802)
00:07:20: As65 LCP: TIMEout: State REQsent
Bronze
Ensure that the remote end is configured identically (async interface, PPP, w/ autoselect under the line). If it is, then you should reverse telnet to AS65, dial out manually, and see if you get the remote router prompt. If you connect but see no prompt, you may want to check the modem configuration. You may also want to try the same test from the other end.
128
