Webcast-Catalyst9k
Two blocks of IPs and one subnet mask
I have two blocks of IPS and two subnetmask's
64.132.148.48/28
usable 64.132.148.49 <-> 64.132.148.62
netmask 255.255.255.240
second set
64.132.148.64/27
usable 64.132.148.65 <-> 64.132.148.94
netmask 255.255.255.224
In my route e/0 what netmask shuold I be puting in ????
Frank G
Re: Two blocks of IPs and one subnet mask
Well, you could put both of these subnets under a single interface, one as a secondary address.
interface e/0
ip address 64.132.148.94 255.255.255.224
ip address 64.132.148.62 255.255.255.240 secondary
This will allow you to use addresses from both subnets, but you will loose couple IP's and will need
to manage the host assignments properly.
There is no way here to just assign a one subnet mask for both networks, and end up with a merged subnet. You loose 3 addresses all together, one by having second IP assigned to the same interface as well as loosing 2 extra IP's on the network/broadcast addresses. On top of that you might need to enable fast switching on the same interface for cummunication between both subnets to allow for better performance, but it's not required.
The best way to deal with this would be to request an address space of /26 type for example, if possible.
Here is my delema
Web_#2#sh runn
Building configuration...
Current configuration:
version 11.0
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
no service udp-small-servers
no service tcp-small-servers
hostname Sug_Web_#2
clock timezone est -5
clock summer-time edt recurring
enable secret xxxx
no ip bootp server
ip subnet-zero
no ip source-route
no ip domain-lookup
interface Ethernet0
description internal LAN.DMZ
ip address x.x.x.49 255.255.255.240
no ip directed-broadcast
no ip mroute-cache
interface Serial0
description External Internet WAN
ip address x.x.x.170 255.255.255.252
no ip mroute-cache
encapsulation ppp
no fair-queue
interface Serial1
no ip address
no ip mroute-cache
shutdown
ip default-gateway 207.250.82.169
ip classless
ip route 0.0.0.0 0.0.0.0 207.250.82.169
ip route 64.132.148.50 255.255.255.255 64.132.148.62
ip route 64.132.148.51 255.255.255.255 64.132.148.62
ip route 64.132.148.52 255.255.255.255 64.132.148.62
ip route 64.132.148.53 255.255.255.255 64.132.148.62
ip route 64.132.148.54 255.255.255.255 64.132.148.62
ip route 64.132.148.56 255.255.255.255 64.132.148.62
ip route 64.132.148.57 255.255.255.255 64.132.148.62
ip route 64.132.148.58 255.255.255.255 64.132.148.62
ip route 64.132.148.59 255.255.255.255 64.132.148.62
ip route 64.132.148.61 255.255.255.255 64.132.148.62
ip route 64.132.148.64 255.255.255.224 64.132.148.48
ip route 64.132.148.67 255.255.255.255 64.132.148.62
ip route 64.132.148.94 255.255.255.255 64.132.148.62
logging buffered
access-list 2 permit 64.132.123.18
access-list 2 permit 208.46.16.50
access-list 2 permit 64.132.148.48 0.0.0.15
access-list 13 permit 64.132.148.75
access-list 13 permit 64.132.148.53
access-list 13 permit 64.132.148.60
access-list 13 permit 64.132.123.20
access-list 13 permit 64.132.123.18
access-list 13 permit 24.27.208.2
access-list 13 permit 208.46.16.50
access-list 13 permit 64.132.148.48 0.0.0.15
access-list 101 deny 53 any any
access-list 101 deny 55 any any
access-list 101 deny 77 any any
access-list 101 deny 103 any any
access-list 101 permit ip any any
no cdp run
snmp-server community public RO
line con 0
line aux 0
transport input all
line vty 0 4
access-class 13 in
password xxxxxx
login
end
Can you give me any help as to how to have the second subnet to be recognized.
Frank
Thank you for any help you may provide
If I understand your post properly, you want to use two IP subnets on the ethernet 0 interface. Or let us know what exactly you want to do?
conf t
interface Ethernet0
ip address 64.132.148.49 255.255.255.240
ip address 64.132.148.65 255.255.255.224 secondary
No need for ip route commands:
Also you havent applied the access-list to any of your interface as seen in the config
Yes thats exactly what I need.
The first answer I thought was in reverse but gave me some more info on my investigation.
I will aply my access-list to an interface when I make these changes.
Thank you for your help
Frank
Hey Frank, how about giving the man his points if his post helped you??? I guess Ill have to do it for you.
Hi Frank
I have a very small problem as I would like to know how do I assign access list to specific interface.
go to the interface that you would like your access-list to run on and then type in ip access-group 13 in or out. 13 is just a number of the group.
You have to build your access-list to permit or deny IP's
101
