Community Member
two BRI acces Problem
hello,
i have two BRI acces in my headquarter (using cisco 2600, IOS ver:12.0), and four remotes sites (using cisco 1600, IOS ver:12.0) with one BRI acces.
the probleme is:
i can't have a 4 simultaneous connection from my headquarters to the remotes sites.
any idea???
here the configuration of the router in my headquarter:
hostname Z
enable password 7 0873461F054815
username A password 7 070C334B1A
username B password 7 1414000917
username C password 7 0205141E15
username D password 7 121A180718
ip subnet-zero
no ip source-route
no ip domain-lookup
isdn switch-type vn3
process-max-time 200
interface FastEthernet0/0
description xxxxxxxxxxxx
ip address X.X.X.X X.X.X.X
no ip directed-broadcast
ip nat inside
speed 10
interface Serial0/0
description LS 2mbit/s xxxxxxxxxxxxxxxx
bandwidth 1920
ip nat outside
encapsulation ppp
interface BRI1/0
description connexion physique vers le coffret Multi-TNR
no ip address
ip nat inside
encapsulation ppp
dialer rotary-group 1
no fair-queue
interface BRI1/1
no ip address
ip nat inside
encapsulation ppp
no fair-queue
interface BRI1/2
no ip address
shutdown
no cdp enable
interface BRI1/3
no ip address
shutdown
no cdp enable
interface Dialer1
description isdn connection for 4 remotes sites
ip address xxxxxxxxxxxxxxxxxx
ip nat inside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer map ip X.X.X.2 name A 0493211240
dialer map ip X.X.X.3 name B 0492150258
dialer map ip X.X.X.4 name C 0492150394
dialer map ip X.X.X.5 name D 0497213731
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap
ip nat pool CR06 X.X.X.X X.X.X.X netmask 255.255.255.0
ip nat inside source list 1 pool CRAM overload
ip classless
ip route X.X.X.X X.X.X.X
ip route X.X.X.X X.X.X.X X.X.X.X
no ip http server
access-list 1 permit X.X.X.X X.X.X.X
dialer-list 1 protocol ip permit
line con 0
transport input none
line aux 0
line vty 0 4
password 7 075D2B1235809
login
end
there is any problem in my config?
thanks in advance
Bronze
Re: two BRI acces Problem
Your configuration looks a bit strange normally you use either dialer maps, coded directly under the BRI interface itself, OR multiple Dialer interfaces but not both.
The following URL is an example using dialer maps
http://www.cisco.com/warp/customer/701/40.html
If you were to use multiple dialer interfaces in this case, you would have to change your IP addressing, since each dialer interface must be in a different subnet unless you use ip unnumbered.
Community Member
We are also using multiple 'dialer maps' on one dialer-interface on one of our routers. No problem.
Only we are using a Pri (30 channels)
Creating dialers for each location is also a option
109
