two Cisco 2620 and four Aironet 342 Bridges
I have a WAN with two 2620 routers conected via serial ports PPP. These routers are each connected to a wireless brdige which further connects to a lan some distance away. My problem is that within the routers I can ping virtually any device on the network but when I try and ping devices using a PC for instance this fails. SO fo example one router has address 158.29.136.124/255.255.255.128 while the other is the same IP address structure but with subnet 255.255.255.224. When I ping a device outside the routers the ping fails. Help?
Re: two Cisco 2620 and four Aironet 342 Bridges
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
It looks like a routing or addressing problem. Provide your configuration or open a TAC case.
122
