Webcast-Catalyst9k
Two computers connected in the same port dot1x in 3750 in different time.
I have the following consultation.
I have a "computer A" connected to a port of switch 3750, configured with: dot1x port-control auto
dot1x timeout quiet-period 5
The "computer A" is authorized.
When I disconnect the "computer A" and I connect a "Computer B", this is not connected, but when I connect the "computer A" again if is connected.
How many time I should expect to be able to connect the "computer B" in the same port of the 3750?
Re: Two computers connected in the same port dot1x in 3750 in di
your question is not clear, can you explain more in detail with diagram(if possible)
When the switch cannot authenticate the client, the switch remains idle for a set period of time and then tries again. The dot1x timeout quiet-period interface configuration command controls the idle period. A failed authentication of the client might occur because the client provided an invalid password. You can provide a faster response time to the user by entering a number smaller than the default.
The value after the quiet-period is in seconds, so in your case, the switch will wait five seconds before it re-tries for another authentication for the new device connected.
Please rate helpful posts.
181
