Community Member
Two Copies of Each Packet seen using NAM
When capturing traffic for ONE vlan using the NAM I can see two copies of the same packet for every packet sent.
Can anyone explain this.
Thanks in advance.
Re: Two Copies of Each Packet seen using NAM
Can you provide more details? Such as IOS versions, details on the SPAN session, modules installed in the switch etc?
One bug I had to deal with recently is
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCef56273
Which is duplicated by
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCee78323
Community Member
Hi and thanks for your reply.
We are using the following software versions on the various modules installed in the 6509s:
Model Sw
WS-SVC-NAM-1 3.4(1a)
WS-SVC-IDSM-2 4.1(5)S208
WS-SVC-FWM-1 2.3(2)4
WS-SUP720-3B 12.2(18)SXD4
WS-X6704-10GE 12.2(18)SXD4
WS-X6724-SFP 12.2(18)SXD4
WS-X6748-GE-TX 12.2(18)SXD4
The span session which we ususally configure usning the NAM is as follows:
monitor session 2 source vlan 206
monitor session 2 destination analysis-module 1 data-port 1
A "Show monitor" request gives the following:
Session 2
Type : Local Session
Source VLANs :
Both : 206
Destination Ports : analysis-module 1 data-port 1
I have had a look at the bugs that you listed. I amust admit that I dont really understand the description in the first bug report. The second bug report references a line card which we do not have installed so I guess that this one would not apply.
When we are capturing packets with the NAM as I originally mentioned it appears that we are seeing two copies of packests that are being received from a client within a particular VLAN but only one copy of packets that are transmitted back to the same client on the same VLAN.
In addition, if we perform a capture (using Etherreal) on the client in question, we only see one packet being transmitted by the client but we can see this same packet twice on the captures taken from the NAM.
118
