Two FRAME-RELAY with ISDN backup
I've a cisco 2500 connected through two frame-relay pvc to a cisco 3640.
I've a isdn connection also available between the two sites.
I want to utilize both the frame-relay pvc for load-sharing and implement a backup solution with isdn in the case the two pvc go down.
I'm running eigrp between the two sites.
If I had a 2600 instead of the 2500,
I'd have implemented multilink frame-relay with backup interface or floating static route and dialer configuration, but I've not money to purchase a 2600.
Any ideas for my issue?
Thanks a lot,
Maurizio
Re: Two FRAME-RELAY with ISDN backup
I find from the Feature navigator that the 17XX series routers support this feature from IOS version 12.2(8)YN release. You can think of this product which might be a cheaper solution.
Very thanks!
It's a good solution.
Merry Christmas!
Maurizio
89
