Two ISP´s, can they work together ?
Hi people,
Thing is, I have two ISP´s in my LAN with diferent routers (two diferent gateways), then , I need to use the second one only like a backup, I typed a secondary ip route with a diferent weitgh in another internal router which is my default gateway but, it does not work fine.
I was trying with route-maps but I did not find how to apply them in that case.
If somebody can help me about that issue
will be very useful.
Any link, any idea please
Thanks in advanced
Martin
1 REPLY
Re: Two ISP´s, can they work together ?
Yes you can do that.
You can use HSRP for this and then you don't need to put floating static route.
hope this help
89
