Two networks on Same VLANID on two switches
I have a question regarding vlans. If I ahve two switches A and B and a Router RA. If switchA has two VLAN 1 and 2, and swB has one vlan 1. Does the network have to be the same on both VLAN 1? swA VLAN 1 is a.b.c.d, vlan2 is network w.x.y.z. If swb vlan1 is network w.x.y.z could have a trunk between these two switches and the router so that bot networks can communicate with eachother or do I have to move each respective vlan to match the netowork on each switch.
1 ACCEPTED SOLUTION
Re: Two networks on Same VLANID on two switches
Set all the ports on network y.y.y.y to vlan 2 and set your trunk port normally so that vlan 1 is on it since your vtp traffic uses the native vlan to communicate.
Example
SWITCH A
vlan database
vtp domain cisco
vtp mode server
exit
interface fa0/1
Description ***Connected to router***
switchport mode trunk
interface fa0/2
Description ***Connected to Switch B***
SWITCH B
vlan database
vtp mode client
vtp domain cisco
exit
interface fa0/1
Description ***Connected to Switch A
interface fa0/2
Description ***Set all y.y.y.y interfaces to vlan2***
switchport mode access vlan 2
Patrick
HTH please rate any posts that are helpful.
Let me make sure I have your topolgy right.
RTRA trunks to Switch A that has VLAN 1 and VLAN 2 then Switch A connects to Switch B that has VLAN1
Switch A vlan 1 is network x.x.x.x
Switch A vlan 2 is network y.y.y.y
Switch B vlan 1 is network y.y.y.y
The only way I can think to make this work is to set the port connecting Switch A to Switch B in access mode for vlan 2 while switch B's port connecting to switch a is in access mode for vlan 1.
For best practice I would recommend you trunk between the switches in the future and reassign Switch B ports to vlan 2.
Patrick
HTH please rate any posts that are useful.
I agree that is the best design. So then on Switch B do I have to reassign the native VLAN as well or could I just make all the ports in access mode to VLAN 2 and not worry about the native VLAN which is VLAN 1 by default.
Example
SWITCH A
vlan database
vtp domain cisco
vtp mode server
exit
interface fa0/1
interface fa0/2
SWITCH B
vlan database
vtp mode client
vtp domain cisco
exit
interface fa0/1
interface fa0/2
Patrick
Thanks that resolved it.
No problem if you have any other questions just ask.
Patrick
140
