UBLR dosen´t work in an interfaces trunk?
I´m configuring Aggregate policer in a Sup720-3B, I need to configure Aggregate Policer in a Trunk interfaces, It´s required to limit the bandwidth for vlan to L2 through an interface trunk, between two catalyst.  But it´s dosen´t work. The configuration that I am using is:
S6509#run int giga 3/2
Building configuration...
Current configuration : 167 bytes
interface GigabitEthernet3/2
switchport
switchport mode trunk
no ip address
service-policy input LIMIT
end
S6509#
S6509#show ip access-lists TRAFFIC
Extended IP access list TRAFFIC
10 permit ip any any
S6509#
S6509#show class-map Daniel
Class Map match-all Daniel (id 1)
Match access-group name TRAFFIC
S6509#
S6509#
S6509#show policy
S6509#show policy-map
Policy Map LIMIT
Class Daniel
police flow mask src-only 2000000 200000 conform-action transmit exceed-action drop
S6509#
S6509#
hostname S6509
boot system flash disk1:s72033-advipservicesk9_wan-mz.122-18.SXF14.bin
logging buffered 32768 debugging
logging rate-limit all 1000
enable secret 5 $1$Oewp$4FbojEBx0Nn.sXO1ZzhIj/
class-map match-all Daniel
match access-group name TRAFFIC
policy-map LIMIT
class Daniel
S6509#show mls qos
QoS is enabled globally
Policy marking depends on port_trust
QoS ip packet dscp rewrite enabled globally
Input mode for GRE Tunnel is Pipe mode
Input mode for MPLS is Pipe mode
QoS Trust state is DSCP on the following interface
Gi3/4
Vlan or Portchannel(Multi-Earl) policies supported: Yes
Egress policies supported: Yes
----- Module [5] -----
QoS global counters:
Total packets: 233
IP shortcut packets: 0
Packets dropped by policing: 0
IP packets with TOS changed by policing: 0
IP packets with COS changed by policing: 0
Non-IP packets with COS changed by policing: 0
MPLS packets with EXP changed by policing: 0
S6509#
S6509#
S6509#show policy-map interface gigabitEthernet 3/2
GigabitEthernet3/2
Service-policy input: LIMIT
Class-map: Daniel (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name TRAFFIC
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
S6509#
272
