uBR924 and Cable Provider.
andifur
I am hoping someone can help me out here. I purchased a uBR924 for one of our remote staff members. She used Comcast (PA) for internet.
We are trying to set her up with a tunnel back to work, with a PC and an IP phone. Heres where we run into problems.
Comcast assigns a 10.96.*.* address on the cable-modem 0 int. So I have to keep the router bridged and set my PC to aobtain automaticly. If I hard code the ethernet 0 port I with a 192.168.1.1 then I loose all connectivity
Does anyone know of a way or a config I can use t make this work. I would like to be able have her use all the ports in router. I think it might work if I was able to setthe ethernet 0 card to obtain auto.
I am including a copy of the current contig.
Please help.
uBR924#sh run
Building configuration...
Current configuration:
! Last configuration change at 01:25:13 - Sat May 31 2003
! NVRAM config last updated at 01:14:46 - Sat May 31 2003
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname uBR924
!username xxx pass xxx
enable password xxxx
clock timezone - -5
ip subnet-zero
ip dhcp pool LAN
network 192.168.1.32 255.255.255.224
dns-server 4.2.2.2
default-router 192.168.1.1
voice-port 0
input gain -2
voice-port 1
input gain -2
interface Ethernet0
ip access-group 100 in
ip access-group 101 out
no ip directed-broadcast
ip nat inside
interface cable-modem0
ip address negotiated
ip nat outside
cable-modem downstream saved channel 723000000 58 4
cable-modem mac-timer t2 180000
no cable-modem compliant bridge
ip default-gateway 10.96.72.1
ip nat inside source list 105 interface cable-modem0 overload
ip classless
no ip http server
access-list 1 permit 172.30.0.0 0.0.255.255
access-list 2 permit 172.30.0.0 0.0.255.255
access-list 3 permit 172.30.1.5
access-list 4 permit 172.30.1.6
access-list 5 permit 172.29.0.0 0.0.255.255
access-list 6 permit 172.29.0.0 0.0.255.255
access-list 100 deny udp any range 0 65535 any range netbios-ns netbios-ss
access-list 100 deny tcp any range 0 65535 any range 137 139
access-list 100 deny udp any range 0 65535 any range bootpc bootpc
access-list 100 deny udp any range 0 65535 any range rip rip
access-list 100 permit ip any any
access-list 101 deny udp any range 0 65535 any range netbios-ns netbios-ss
access-list 101 deny tcp any range 0 65535 any range 137 139
access-list 101 deny udp any range 0 65535 any range rip rip
access-list 101 deny tcp any range 0 65535 any range 1080 1080
access-list 101 permit ip any any
access-list 105 permit ip 192.168.1.0 0.0.0.255 any
snmp-server engineID local 00000009020000B064DBAAAC
snmp-server manager
line con 0
transport input none
line vty 0 4
login local
end
Here is a copy of what I get from sh C 0::
Below is the private IP.
cable-modem0 is up, line protocol is up
Hardware is BCM3300, address is 00b0.64db.aaad (bia 00b0.64db.aaad)
Internet address is 10.96.75.28/21
MTU 1500 bytes, BW 27000 Kbit, DLY 1000 usec,
Encapsulation DOCSIS, loopback not set
I dont want ot have to go out and buy another router to sit behind this one.
makchitale
Level 6
Level 6
Yes, in bridging mode Comcast will assign an private (non-routable) ip address to the cable interface & an public ip address to the host (PC) behind the cable modem. What you need to do is use the config given below...use the cable-dhcp-proxy command so C0 gets it's normal 10.x.x.x ip address but an Loopback0 is automatically created that gets the public (which normally would go to the PC) address & we NAT/ PAT against that address.
Ensure you have 12.1(1)T & above on the ubr924.
http://www.cisco.com/warp/customer/109/cable_dhcp_proxy.shtml
Thanks, Mak.
Thanks for te reply. I have tried this exact config before with no luck.
here is a copy from after configuring with cable-modem dhcp-proxy
! Last configuration change at 22:08:25 - Sat May 31 2003
version 12.2
no service single-slot-reload-enable
no service pad
hostname uBR924
logging rate-limit console 10 except errors
enable password xx
username xx
username xx password xx
clock timezone - -5
ip subnet-zero
no ip finger
no ip dhcp-client network-discovery
call rsvp-sync
interface Loopback0
ip address 68.81.48.193 255.255.255.255
interface Ethernet0
ip nat inside
ip nat outside
cable-modem dhcp-proxy nat TEST_POOL
ip nat pool TEST_POOL 68.81.48.193 68.81.48.193 netmask 255.255.255.0
ip nat inside source list 1 pool TEST_POOL overload
ip classless
no ip http server
no ip http cable-monitor
access-list 1 permit 192.168.1.0 0.0.0.255
snmp-server packetsize 4096
snmp-server manager
voice-port 0
input gain -2
output attenuation 0
voice-port 1
input gain -2
line con 0
line vty 0 4
login local
end
I was never able to connect to anything on the ISP side. I could only access internal resources, and of course "Comcast" states they do not support Cisco CM.
I debuged the ip nat and received the followng
NAT* s192.168.1.8--> 68.81.48.193 d=4.2.2.2
so I know its translating the addresses for me. Does any one have any ideas that might help me out.
There is one more thing I am seeing that I may think is casuing something.
I will do a wr er and an IOS upgrade then bridge the router to my PC, I will get different addresses. If then try to get the router to work this way, I will enter in everything (not from TFTP) and a reload and I am always back to the same IP.
Any thoughts?
thanks.
I got it to work. I went from 12.2(1d) to 12.2.(10d) It came right up and is working fine.
