02-19-2003 08:29 AM - edited 03-02-2019 05:12 AM
It appears I have a blockage on my 1720 that is not allowing UDP traffic to flow through the router. How can I check and see if it is in fact doing this and what would the commands be?
Thanks for any help.
02-19-2003 09:47 AM
Check to see if you have access list configured on your router blocking 1720.
show access-lists or show ip access-lists
02-19-2003 10:44 AM
There are no restrictions via ACL's.... I'm starting to check with the carrier to see if it's being blocked out at a specific location on it's way here.
02-19-2003 01:47 PM
UDP broadcasts do not get forwarded without configuring an IP Helper address. What kind of traffic is getting blocked?
02-19-2003 02:01 PM
This problem has been resolved thanks for the efforts.
