udp-small-servers
What does this command do? I searched the other forums and found just one reply to a similar request. It was very general and of not much use. I also searched Cisco's web site for this and found no real info. Can anyone tell me if this can be used for troubleshooting and how?
Sam
Re: udp-small-servers
There are some services, like echo, discard, chargen etc, which use either tcp or udp protocol. If you enabled this service, (either tcp-small-servers or udp-small-servers) these services will be enabled. Usually these should be disabled on a router, as these ports if are remaining open, a hacker from the internet can hack into your network.
Silver
The following URL on CCO covers these commands in some detail:
http://www.cisco.com/warp/customer/66/23.html
bbranch,
Thanks for your reply; that was exactly what I was looking for...
Sam
540
