Unable to ping devices over frame relay switch!!!
I am unable to ping routers having point to point connection. Please Help!!!! I have copied the Frame-Relay switch and Routers' (all 4) config below.
Frame Relay Switch
Concord-FR#sh run
Building configuration...
Current configuration : 2235 bytes
version 12.4
hostname Concord-FR
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
enable secret 5 $1$LvfZ$p0suf5gmUGHXWAk2dAksa0
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
frame-relay switching
archive
log config
  hidekeys
interface FastEthernet0/0
description Management Port
ip address 192.168.0.50 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description Link to Dublin-R1
no ip address
encapsulation frame-relay
clock rate 64000
no frame-relay inverse-arp
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 102 interface Serial0/0/1 201
frame-relay route 103 interface Serial0/1/0 301
frame-relay route 104 interface Serial0/1/1 401
description Link to Tracy-R2
no ip address
clock rate 64000
frame-relay route 201 interface Serial0/0/0 102
frame-relay route 203 interface Serial0/1/0 302
frame-relay route 204 interface Serial0/1/1 402
description Link to Fremont-R3
no ip address
clock rate 64000
frame-relay route 301 interface Serial0/0/0 103
frame-relay route 302 interface Serial0/0/1 203
frame-relay route 304 interface Serial0/1/1 403
description Link to Hayward-R4
no ip address
clock rate 64000
frame-relay route 401 interface Serial0/0/0 104
frame-relay route 402 interface Serial0/0/1 204
frame-relay route 403 interface Serial0/1/0 304
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
no login
scheduler allocate 20000 1000
end
Router 1
Dublin-R1#sh run
Current configuration : 1613 bytes
version 12.4
service password-encryption
hostname Dublin-R1
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$dmnA$hQ51Z/M9j3cjhMTolVSYZ.
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
ip address 10.10.10.1 255.255.255.0
shutdown
speed 100
full-duplex
description Dublin-S1 Port F0/1
ip address 20.20.20.1 255.255.255.0
shutdown
speed 100
full-duplex
no ip address
no fair-queue
interface Serial0/0/0.12 point-to-point
ip address 10.1.1.12 255.255.255.0
snmp trap link-status
frame-relay interface-dlci 102
interface Serial0/0/0.13 point-to-point
ip address 10.1.1.13 255.255.255.0
frame-relay interface-dlci 103
interface Serial0/0/0.14 point-to-point
ip address 10.1.1.14 255.255.255.0
frame-relay interface-dlci 104
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router 2
Tracy-R2#sh run
Current configuration : 1537 bytes
version 12.4
hostname Tracy-R2
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
no fair-queue
interface Serial0/0/0.21 point-to-point
ip address 10.1.1.21 255.255.255.0
frame-relay interface-dlci 201
interface Serial0/0/0.23 point-to-point
ip address 10.1.1.23 255.255.255.0
frame-relay interface-dlci 203
interface Serial0/0/0.24 point-to-point
ip address 10.1.1.24 255.255.255.0
frame-relay interface-dlci 204
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router 3
Fremont-R3#sh run
Current configuration : 1627 bytes
version 12.4
hostname Fremont-R3
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$I7WF$POhMTcbzBUmUGOrciSjLI/
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
description SW3-Port1
ip address 10.10.30.1 255.255.255.0
shutdown
speed 100
full-duplex
description SW3-Port2
ip address 20.20.30.1 255.255.255.0
shutdown
speed 100
full-duplex
no ip address
no fair-queue
interface Serial0/0/0.31 point-to-point
ip address 10.1.1.31 255.255.255.0
frame-relay interface-dlci 301
interface Serial0/0/0.32 point-to-point
ip address 10.1.1.32 255.255.255.0
frame-relay interface-dlci 302
interface Serial0/0/0.34 point-to-point
ip address 10.1.1.34 255.255.255.0
frame-relay interface-dlci 304
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router 4
Hayward-R4#sh run
Current configuration : 1612 bytes
version 12.4
hostname Hayward-R4
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$KFrA$YI1XwQffXKHi7HDW9taPj/
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
description SW4-Port1
ip address 10.10.40.1 255.255.255.0
shutdown
speed 100
full-duplex
description SW4-Port2
ip address 20.20.40.1 255.255.255.0
shutdown
speed 100
full-duplex
no ip address
interface Serial0/0/0.41 point-to-point
ip address 10.1.1.41 255.255.255.0
frame-relay interface-dlci 401
interface Serial0/0/0.42 point-to-point
ip address 10.1.1.42 255.255.255.0
frame-relay interface-dlci 402
interface Serial0/0/0.43 point-to-point
ip address 10.1.1.43 255.255.255.0
frame-relay interface-dlci 403
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
73
