Unanswered call:
hello,
Here the debug outputs for an unanswered call goes, the details of hw/sw version details are given in my previous post " MICA No Answer Rate", on Apr 2, 2003 .However version details are
IOS: c5800-k8p4-mz.122-13.bin
Modem: 2.7.3.0
RAS: AS5800
Router: 7206
Moreover the command debug trunk cas port 1 does not elaborate cas events as "debug cas" supported in AS5300. Any commands supported by AS5800 to trace cas events as AS5300's "debug cas".
if any of you guys figured out the root cause for the following unanswered call would be great.
DA-Slot0##debug trunk cas port 1 timeslots 1-31
Apr 4 12:27:30.784: CAS debug (1:27): Validate rcvd bits: 0001
Apr 4 12:27:30.800: CAS debug (1:27): ABCD bits rcvd: 0001
Apr 4 12:27:30.800: CAS debug (1:27): State Transition: q421_r2_ic_seize_ack
Apr 4 12:27:41.024: CAS debug (1:27): CSM Message: channel lock
Apr 4 12:27:41.024: CAS debug (1:27): ABCD bits Sent: 1101
Apr 4 12:27:41.024: CAS debug (1:27): State Transition: q421_r2_wait_ic_answer
Apr 4 12:27:41.072: CAS debug (1:27): Validate rcvd bits: 1001
Apr 4 12:27:41.092: CAS debug (1:27): ABCD bits rcvd: 1001
Apr 4 12:27:41.092: CAS debug (1:27): q421_r2_ic_clr_fwd
Apr 4 12:27:41.092: CAS debug (1:27): Protocol Timeout
Apr 4 12:27:41.092: CAS debug (1:27): ABCD bits sent 1001
Apr 4 12:27:41.092: CAS debug (1:27): State Transition q421_r2_idle
r0-7206# debug modem csm
Apr 4 12:27:30.797: allocate slot 11 and port 18 is allocated
Apr 2 12:27:30..692: CSM v(11/18) c(E1 1/0/1:27): CSM_PROC_IDLE: ev_START_DIGIT_COLLECT.
Apr 2 12:27:41.017: CSM v(11/18) c(E1 1/0/1:27): CSM_PROC_IC1_COLLECT_ADDR_INFO: ev_MODEM_OFFHOOK.
Apr 2 12:27:41.089: CSM v(11/18) c(E1 1/0/1:27): CSM_PROC_IC1_COLLECT_ADDR_INFO: ev_DSX0_DISCONNECTED.
Apr 2 12:27:41.089.: vdev_deallocate: slot 11 and port 18 is deallocated
1 REPLY
Bronze
Re: Unanswered call:
I think you can use the 'modem-mgmt csm debug-rbs' command on the AS5800 along with the command 'service internal'. You can find more information at http://www.cisco.com/en/US/products/hw/univgate/ps509/products_maintenance_guide_chapter09186a008007cb99.html
See if the following material helps in troubleshooting your problem :
http://www.cisco.com/warp/public/112/chapter17.htm#incomingcascalltroubleshooting
86
