Community Member
Unnumbered Interface on 803
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname DSSacdpsb
enable password XXXXX
username Derbycimp password XXXXXXXX
no ip name-server
isdn switch-type basic-net3
pots country US
ip subnet-zero
no ip domain-lookup
ip routing
interface Dialer 1
description connected to Derbycimp
ip unnumbered Ethernet 0
no ip split-horizon
encapsulation ppp
dialer in-band
dialer idle-timeout 120
dialer hold-queue 10
dialer map snapshot 1 name Derbycimp broadcast 12345
dialer map ip 192.168.216.254 name Derbycimp speed 64 broadcast 12345
dialer-group 1
ppp authentication chap
no ppp multilink
snapshot client 15 360 suppress-statechange-update dialer
no cdp enable
interface Ethernet 0
no shutdown
description connected to EthernetLAN
ip address 192.168.211.254 255.255.255.0
no keepalive
ip access-group 100 in
interface BRI 0
no shutdown
no ip address
dialer rotary-group 1
! Dialer Control List 1
no dialer-list 1
dialer-list 1 protocol ip permit
ip classless
no access-list 100
access-list 100 permit icmp any any
access-list 100 permit tcp any any range ftp-data ftp
access-list 100 permit tcp any any eq telnet
! IP Static Routes
ip route 192.168.216.0 255.255.255.0 Dialer 1 1 permanent
no ip http server
line console 0
exec-timeout 0 0
password XXXXXX
login
line vty 0 4
password XXXXX
login
end
When trying to establish a ISDN DDR connection to 192.168.216.100 the connection is dialed sucessfully but when IP is assigned the connection is dropped.
Debug output
01:55:23: BR0 DDR: rotor dialout [priority]
01:55:23: BR0 DDR: place call
01:55:23: BR0 DDR: Dialing cause snapshot
01:55:23: BR0 DDR: Attempting to dial 01332690039
01:55:23: ISDN BR0: TX -> SETUP pd = 8 callref = 0x4E
01:55:23: Bearer Capability i = 0x8890
01:55:23: Channel ID i = 0x83
01:55:23: Called Party Number i = 0x80, '01332690039', Plan:Unknown, Typ
e:Unknown
01:55:23: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0xCE
01:55:23: Channel ID i = 0x89
01:55:24: ISDN BR0: RX <- ALERTING pd = 8 callref = 0xCE
01:55:24: ISDN BR0: RX <- CONNECT pd = 8 callref = 0xCE
01:55:103079215104: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
01:55:24: ISDN BR0: TX -> CONNECT_ACK pd = 8 callref = 0x4E
01:55:24: BR0:1 PPP: Treating connection as a callout
01:55:24: BR0:1 PPP: Authorization NOT required
01:55:24: BR0:1 CHAP: O CHALLENGE id 78 len 30 from "DSSacdpsb"
01:55:24: BR0:1 CHAP: I CHALLENGE id 1 len 30 from "Derbycimp"
01:55:24: BR0:1 CHAP: I RESPONSE id 78 len 30 from "Derbycimp"
01:55:24: BR0:1 PPP: Sent CHAP LOGIN Request to AAA
01:55:24: BR0:1 CHAP: Using hostname from configured hostname
01:55:24: BR0:1 CHAP: Using password from AAA
01:55:24: BR0:1 CHAP: O RESPONSE id 1 len 30 from "DSSacdpsb"
01:55:24: BR0:1 PPP: Received LOGIN Response from AAA = PASS
01:55:24: BR0:1 DDR: Remote name for Derbycimp
01:55:24: BR0:1 CHAP: O SUCCESS id 78 len 4
01:55:24: BR0:1 CHAP: I SUCCESS id 1 len 4
01:55:24: BR0:1 set_ip_peer(8): new address 192.168.216.254
01:55:24: BR0:1 set_ip_peer(0): new address 0.0.0.0
01:55:24: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0xCE
01:55:24: Cause i = 0x8090 - Normal call clearing
All seams OK until the set_ip_peer output.
is this beace i'm using the Unnumbered IP for Dialer1 ?
The remote router is a BinTec ISDN router.
Bronze
Re: Unnumbered Interface on 803
Probably. But there were no IPCP nego output from your debug.
Most implementations use the same network address between the two peers.
You can try using another ip address on the dialer interface belonging to the
same network as the remote peer.
Hope this helps.
Need to see the debug for following as IPCP debug is not displayed.
debug isdn q931
debug ppp authentication
debug ppp negotiation
debug dialer
Community Member
Debug output as requested
15:44:37: BR0:1 PPP: Treating connection as a callout
15:44:37: BR0:1 PPP: Phase is ESTABLISHING, Active Open
15:44:37: BR0:1 PPP: Authorization NOT required
15:44:37: BR0:1 LCP: O CONFREQ [Closed] id 29 len 15
15:44:37: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
15:44:37: BR0:1 LCP: MagicNumber 0x05783C7C (0x050605783C7C)
15:44:37: BR0:1 LCP: I CONFREQ [REQsent] id 1 len 23
15:44:37: BR0:1 LCP: MRU 1524 (0x010405F4)
15:44:37: BR0:1 LCP: MagicNumber 0x4012312B (0x05064012312B)
15:44:37: BR0:1 LCP: PFC (0x0702)
15:44:37: BR0:1 LCP: ACFC (0x0802)
15:44:37: BR0:1 LCP: O CONFACK [REQsent] id 1 len 23
15:44:37: BR0:1 LCP: I CONFACK [ACKsent] id 29 len 15
15:44:37: BR0:1 LCP: State is Open
15:44:37: BR0:1 PPP: Phase is AUTHENTICATING, by both
15:44:38: BR0:1 CHAP: O CHALLENGE id 15 len 30 from "DSSacdpsb"
15:44:38: BR0:1 CHAP: I CHALLENGE id 1 len 30 from "Derbycimp"
15:44:38: BR0:1 CHAP: I RESPONSE id 15 len 30 from "Derbycimp"
15:44:38: BR0:1 PPP: Sent CHAP LOGIN Request to AAA
15:44:38: BR0:1 CHAP: Using hostname from configured hostname
15:44:38: BR0:1 CHAP: Using password from AAA
15:44:38: BR0:1 CHAP: O RESPONSE id 1 len 30 from "DSSacdpsb"
15:44:38: BR0:1 PPP: Received LOGIN Response from AAA = PASS
15:44:38: BR0:1 DDR: Remote name for Derbycimp
15:44:38: BR0:1 CHAP: O SUCCESS id 15 len 4
15:44:38: BR0:1 CHAP: I SUCCESS id 1 len 4
15:44:38: BR0:1 PPP: Phase is UP
15:44:38: BR0:1 IPCP: O CONFREQ [Closed] id 15 len 10
15:44:38: BR0:1 IPCP: Address 192.168.211.254 (0x0306C0A8D3FE)
15:44:38: BR0:1 IPCP: I CONFREQ [REQsent] id 1 len 16
15:44:38: BR0:1 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
15:44:38: BR0:1 IPCP: Address 192.168.216.254 (0x0306C0A8D8FE)
15:44:38: BR0:1 IPCP: O CONFREJ [REQsent] id 1 len 10
15:44:38: BR0:1 CCP: I CONFREQ [Not negotiated] id 1 len 10
15:44:38: BR0:1 CCP: MS-PPC supported bits 0x00000020 (0x120600000020)
15:44:38: BR0:1 LCP: O PROTREJ [Open] id 30 len 16 protocol CCP (0x80FD0101000A1
20600000020)
15:44:38: BR0:1 IPCP: I CONFACK [REQsent] id 15 len 10
15:44:38: BR0:1 IPCP: I CONFREQ [ACKrcvd] id 2 len 10
15:44:38: BR0:1 IPCP: O CONFACK [ACKrcvd] id 2 len 10
15:44:38: BR0:1 IPCP: State is Open
15:44:38: Di1 IPCP: Install route to 192.168.216.254
15:44:38: BR0:1 IPCP: Add link info for cef entry 192.168.216.254
15:44:38: BR0:1 LCP: I TERMREQ [Open] id 2 len 4
15:44:38: BR0:1 LCP: O TERMACK [Open] id 2 len 4
15:44:38: BR0:1 IPCP: Remove link info for cef entry 192.168.216.254
15:44:38: BR0:1 IPCP: State is Closed
15:44:38: BR0:1 PPP: Phase is TERMINATING
15:44:38: BR0:1 DDR: dialer protocol up
15:44:38: BR0:1 PPP: Outbound ip packet dropped, line protocol not up
15:44:38: BR0:1 DDR: Call connected, 2 packets unqueued, 0 transmitted, 2 discar
ded
15:44:38: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0x8F
15:44:38: Cause i = 0x8090 - Normal call clearing
15:44:167512106340: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 013326
90039 Derbycimp
15:44:167512106172: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 0133
2690039 Derbycimp, call lasted 1 seconds
15:44:167503724544: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
15:44:39: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x0F
15:44:39: Cause i = 0x8090 - Normal call clearing
15:44:39: Di1 IPCP: Remove route to 192.168.216.254
15:44:39: BR0:1 LCP: State is Closed
15:44:39: BR0:1 PPP: Phase is DOWN
15:44:39: BR0:1 DDR: disconnecting call
15:44:39: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0x8F
I also made a slight change to the Config
! IP Static Routes
ip route 192.168.216.254 255.255.255.255 Dialer1
ip route 192.168.216.0 255.255.255.0 192.168.216.254
There is ip address mismatch here. Derbycimp wants to negotiate 192.168.216.254 ip address while DSSacdpsb wants to negotiate 192.168.211.254. Both the ip address are in two different networks. That is the problem on point to point link. You need to have both the peers on the same network/subnet.
So to make that work, you need to allocate the ip address of the ethernet interface on DSSacdpsb from 192.168.216.0 network. or use the different addressing scheme.
That way we will have both the peers in the same ip network..Once that changed you will be able to ping ecah other fine.
Community Member
Thanks for your help so far!
When i change Dialer1 conf to
ip address 192.168.216.250 255.255.255.0
I get the following output why is the line being drop as soon as the IP's are declared by each router ?
00:16:52: BR0:1 PPP: Phase is UP
00:16:52: BR0:1 IPCP: O CONFREQ [Closed] id 10 len 10
00:16:52: BR0:1 IPCP: Address 192.168.216.250 (0x0306C0A8D8FA)
00:16:52: BR0:1 CCP: I CONFREQ [Not negotiated] id 1 len 10
00:16:52: BR0:1 CCP: MS-PPC supported bits 0x00000020 (0x120600000020)
00:16:52: BR0:1 LCP: O PROTREJ [Open] id 20 len 16 protocol CCP (0x80FD0101000A1
20600000020)
00:16:52: BR0:1 IPCP: I CONFREQ [REQsent] id 1 len 16
00:16:52: BR0:1 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
00:16:52: BR0:1 IPCP: Address 192.168.216.254 (0x0306C0A8D8FE)
00:16:52: BR0:1 IPCP: O CONFREJ [REQsent] id 1 len 10
00:16:52: BR0:1 IPCP: I CONFACK [REQsent] id 10 len 10
00:16:52: BR0:1 LCP: I TERMREQ [Open] id 2 len 4
00:16:52: BR0:1 LCP: O TERMACK [Open] id 2 len 4
00:16:52: BR0:1 IPCP: State is Closed
00:16:52: BR0:1 PPP: Phase is TERMINATING
00:16:52: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0x8A
00:16:52: Cause i = 0x8090 - Normal call clearing
For wahtever reason this router got request to clear the connection..as we have received
Now once this router rejects VJ compression, the other router should send CONFREG with just ip address as 192.168.216.254 but instead that router send TERMREQ..So i think you need to talk to other side router's admin about compressin issue..
You can configure "compress mppc" command under the bri0 interface and see if that makes any difference..Otherwise you need to talk to other side router's admin to sort that compression issue,
Community Member
I've got details from the remote router admin
Encapsulation PPP
Compress STAC
Encryption MPPE 40
I assume that I need
Interface BRI0
compress STAC
but what IOS do I need from the Encryption type Mppe ?
I think you are trying to replace the windows PC dialout to some server by 803 router..Looking on the previous debug you just need to have following to successfully negotiate the ip address between two routers.
Interface BRI0
compress STAC
Now if the remote side router is looking for Microsoft Point-to-Point Encryption (MPPE) 40 for data, you need images with IPSEC featureset in it. But 800 routers dosen't supports MPPE as per following url.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t5/dt_pptp.htm
Community Member
Thanks for your help removing MPPE 40 from teh remote router lets this config work!
Next question how dow I had a second Dialer ?
Dialer2
New IP Range 192.168.217.0
I'm confussed about the Dialer-Groups
Need to know why exactly you need the second dialer for. You can't add a second dialer interface using "dialer rotary-group x" one one physical bri interface. For that you need to have dialer-profiles" configured with one bri interface has a pool of two dialer interface. Here is the sample config for that
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
OR
you can use another dialer-map in the same config.
Community Member
I need to be able to Route to a different Remote Network.
by Dialer Map i assume you mean something like :-
dialer map snapshot 1 name Sealcimp broadcast 54321
dialer map ip 192.168.217.254 name Sealcimp speed 64 broadcast 54321
Can U point me in the direction of some "Dialer Map" info?
Community Member
162
