Unsupported device in CW2000 - RME 3.4 IDU 1.0 - OID not listed on Cisco
treisner
Have a device that was added. Can do SNMP pulls and the OID that comes back is:
system.sysObjectID.0 : OBJECT IDENTIFIER:
.iso.org.dod.internet.private.enterprises.cisco.ciscoProducts.502
(Interpreted, this OID is: 1.3.6.1.4.1.9.1.502)
I tried the OID translator on cisco.com and it does not have a 502.
The system description was:
system.sysDescr.0 : DISPLAY STRING- (ascii): Cisco Internetwork Operating
System Software
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(14)E1,
EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Anybody run into this?
rmushtaq
Level 8
Level 8
Using: http://jaguar.ir.miami.edu/cgi-bin/snmptransc.cgi, the above OID translates to cat4506 which is supported in the latest IDU:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_4/dev_sup/e3_4.htm#13062
You can download the latest IDU v4-0 from: http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme and install.
treisner
I did get a "sh tech" from the system and it shows that it is a Cat4506 - I did find that support for it was included in IDU 2.0.
Thanks for the responses.
