I have just upgraded from a HP procurve switch & 3com hub combination. Prior to the upgrade I was getting good access speed with my SQL applications. Since implementing the switches The SQL apps are slow.
I have configured the switches with portfast with all ports except The gigabit uplink. I did originally use martports but turned this off as workstations were having connectivity problems. I also have upgraded the workstations, all of which now have intell pro 100 NIC`s. The wokstations were changed prior to the switches.
