Upgrading 6509 to Native IOS - Booting Problem
Hello - I probably have missed a simple step here...
We have the following 6509 hardware:
WS-X6K-SUP1A-2GE
WS-F6K-MSFC2
New IOS: c6sup12-jsv-mz.121-11b.EX1
I am using the following URL:
http://www.cisco.com/warp/public/473/81.shtml
I execute STEP 17 (for MSFC2):
boot sup-slot0:c6sup12-jsv-mz.121-11b.EX1
The c6sup12 binary uncompresses.
System power on diagnotics completes.
Then, I see "boot image: bootflash:cat6000-supk9.7-2-2.bin"
and the original cat6000 image loads. The
native image does not load.
I have gone through the steps several times without any luck :(
What am I missing here?
Scott
Bronze
Re: Upgrading 6509 to Native IOS - Booting Problem
can you paste the output of the set and dir bootflash: and dir slot0: and capture of everything while you are trying to boot up from the native IOS.
It seems like you are on the SP sides of the switch and the RP side still trying to boot up
Erum
Silver
Did you set the config reg on the Supervisor to 0x0 to stop it booting the CatOS image:
set boot config-register 0x0
(see step 11)
Here it is:
cat7 (enable) show modul
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 48 10/100BaseTX Ethernet WS-X6548-RJ-45 no ok
4 4 0 FlexWAN Module WS-X6182-2PA no ok
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine WS-F6K-PFC SAL06334FZ9 2.0
----->STEP10:
cat7 (enable) show boot
BOOT variable = bootflash:cat6000-supk9.7-2-2.bin,1;
CONFIG_FILE variable =
Configuration register is 0x0
ignore-config: disabled
auto-config: non-recurring, overwrite, sync disabled
console baud: 9600
boot: the ROM monitor
----->STEP11: omitted config-reg=0x0 - see above.
----->STEP12:
cat7_NATIVE (enable) reset
This command will reset the system.
Do you want to continue (y/n) [n]? y
Powering OFF all existing linecards
System Bootstrap, Version 5.3(1)
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
----->STEP13:
rommon 1 > set
PS1=rommon ! >
SYS_CONFIG_FILE=
BOOT=bootflash:cat6000-supk9.7-2-2.bin,1;
boot=
CONFIG_FILE=
?=0
----->STEP14: omitted
----->STEP15:
rommon 2 > dir bootflash:
File size Checksum File name
9567769 bytes (0x91fe19) 0xc3e01312 cat6000-supk9.7-2-2.bin
rommon 3 > dir slot0:
12115968 bytes (0xb8e000) 0x36182ef0 c6sup12-jsv-mz.121-11b.EX1
----->STEP16:
rommon 4 > reset
----->STEP17:
rommon 1 > boot slot0:c6sup12-jsv-mz.121-11b.EX1
loadprog: error - on read during ELF program load
requested 15943856 (0xf348b0) bytes, got 12089228 (0xb8778c)
boot: cannot load "slot0:c6sup12-jsv-mz.121-11b.EX1"
I try the other command.... ie boot sup-slot0:
rommon 2 > boot sup-slot0:c6sup12-jsv-mz.121-11b.EX1
Uncompressing file: #########################################...
System Power On Diagnostics
DRAM Size ....................64 MB
Testing DRAM..................Passed
NVRAM Size ...................512 KB
Level2 Cache .................Present
System Power On Diagnostics Complete
Boot image: bootflash:cat6000-supk9.7-2-2.bin
Here we start booting the old image...
Let me know if you need more info!
Scott
Bronze
Seems you are still on the Sp side and the image on the slot0 are corrupted.
in step 17
It didn't boot up from the bootimage from slot0. delete the image and copy it again to the pcmcia.
That was it!
Thank you.
Scott
Check the " set boot " command parameters.
Example:
set boot system flash bootflash: your-new-image.bin
251
