Upgrading frame speed
I am about to upgrade one of my sites from 56k to 128k frame-relay. The site has a 1600 router and our corporate office has a 2500. My question is what changes, if any, will I need to make to the 1600? Below is the config as it is now for the 1600 with a 56k line.
version 11.2
service timestamps debug datetime show-timezone
service timestamps log datetime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
enable secret XXXXXXXXXXX
enable password XXXXXXXXX
Interface Ethernet0
description Cleveland Heights Ethernet Network
ip address 192.168.31.1 255.255.255.0
interface Serial0
no ip address
encapsulation frame-relay
service-module 56k clock source line
service-module 56k network-type dds
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
description Frame Relay PVC to Natick
ip address 192.168.254.126 255.255.255.252
frame-relay interface-dlci 875
router eigrp 1
passive-interface Ethernet0
network 192.168.254.0
network 192.168.31.0
no ip classless
ip route 0.0.0.0 0.0.0.0 192.168.254.125
snmp-server community public RW 1
snmp-server community private RW 1
line con 0
session-timeout 25
exec-timeout 25 0
password XXXXXXXXXX
login
flowcontrol hardware
line vty 0 4
session-timeout 25
exec-timeout 25 0
password XXXXXXXXXX
login
1 REPLY
Re: Upgrading frame speed
I would start by verifying your hardware. Often, 2500 class routers have 56K WAN cards in them that do not scale to higher speed circuits like 128K or other fractional T1 speeds. Chances are, that you will need to get a T1 interface card for your 2500 or use a serial interface with V.35 to an external CSU. Your service provider will probably provision the link to come in on a frac T1 which means that they will have the local bell provider bring in a new Smart jack for you unless you are on sonet ring or similar. I would verify the same thing on your 1600.
As far as the config goes, unless you are doing Frame Relay traffic Shaping, there is really not anything you must do to make the router "talk on the higher speed" although it is a good idea to make a bandwidth statement on the interface you use for the WAN link for your routing protocols like EIGRP.
I would also change the default SNMP community strings to something other than public and private.
81
