Community Member
Uploading images to production switches
Can I assume that it is okay to upload new IOS images to live production switches? Will this cause any problems?
1 ACCEPTED SOLUTION
Re: Uploading images to production switches
Uploading images to a production switch should not cause any problems as long as the power to the switch is stable.(if you have deleted the old file to make room and if the switch reboots during TFTP, you'll have problems)
1 REPLY
112
