Webcast-Catalyst9k
urgent! can someone help me?
Re: urgent! can someone help me?
A is having ip: 172.17.3.15
subnet mask: 255.255.255.0
gateway: 172.17.3.254
B's ip: 172.17.15.33
gateway: 172.17.15.254
the problem is A can ping B, but B cant ping A...
can someone tell me what is the problem?
HI
btw what r these A and B are they any routers or switches.
Can u verify if u r having route back to B from A.
Hope this helps
Mahmood
Hi Friend,
I think they are workstation or servers.
If yes make sure on B you have no firewall turned on.
If it is wondows xp or something it has a default firewall which rtestrivt pings soemtime.
Ankur
A and B are workstations. let say A is in vlan1 and B is in vlan2.
no firewalls turned on.
As Ankur suggested, did you get a chance to check if there is a firewall on A or B PCs or may be in between them or perhaps an access list on the switch.
Can you do the follwings 2 tasks and paste the results.
Task 1
Ping from host A to 10.17.3.254
Ping from host A to 10.17.15.33
ping from host A to 10.17.15.254
tracert from host A to 10.17.15.254
Task 2
Ping from host B to 10.17.15.254
Ping from host B to 10.17.3.15
ping from host B to 10.17.3.254
tracert from host B to 10.17.3.254
This will give us more info to help you further.
100
