urgent help-- 3660 is not booting
Hi all
i have 3662 working from several years
since iam getting some Bus exceptions errors
as per the lot of groups user recomendation
i have switched off and removed all modules and even main board, removed RAM and FLASH too.
and cleaned the Dust inside
and inserted main board, with out any slots in the chasis
and try to boot iam getting the following error
System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
Bad RAM at location 0xA0000000: wrote 0xA0000000, read 0x5C5C5C5C
i have not additional RAM, how can test this and receover this router
Since i have only one router, some of clients not had any connection
iam looking forward some help me to sort out this problem
any proceedures to help me set up this router up
will be greatful
thanks
hari
Bronze
Re: urgent help-- 3660 is not booting
Sounds like you have a hardware error with the DRAM. If so, you have no option but to replace it.
thanks for quick reply
replace of what ?
replace of DRAM or hardware.
is the 3640 DRAM will be compatable with 3660
since i have extra at 3640 so i can use
if not what is partnumber i need to order
sure its only DRAM problem or any chasis.
thanks
hari
122
