Urgent help needed : DIALUP Connection to Australia
I have a 3640 router with bri's in a routary group, i have a problem connecting to a cisco 803 isdn router. the 803 router is in australia and iam trying to connect from switzerland. The connection from the router 803 in australia to the router in switzerland is working good ( iam calling from australia using the following tel. nr. format 0011+ the tel.nr in switzerland including the international code. the problem is that i can not set a connection from switzerland to the router in australia, iam using the usual code for australia 0061 + the tel.nr. of the isdn interface of the 803 router. when try to make the connection i get the following deb. output ( debug isdn q931).
Sending 5, 100-byte ICMP Echos to 193.72.77.153, timeout is 2 seconds:
5d23h: ISDN BR0 Q931: TX -> SETUP pd = 8 callref = 0x3F
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Called Party Number i = 0x80, '0061260567934'
Plan:Unknown, Type:Unknown
5d23h: ISDN BR0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xBF
Channel ID i = 0x89.
5d23h: ISDN BR0 Q931: RX <- DISCONNECT pd = 8 callref = 0xBF
Cause i = 0x8781 - Unallocated/unassigned number
Facility i = 0x91A11A02021A4C0201233011300FA10D810346522EA20681010082010
- ETSI Supplementary Service, Invoke, AOC-E Currency
Display i = 'FR. 0.00'
5d23h: ISDN BR0 Q931: TX -> RELEASE pd = 8 callref = 0x3F
Cause i = 0x8081 - Unallocated/unassigned number
5d23h: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xBF
5d23h: ISDN BR0 Q931: TX -> SETUP pd = 8 callref = 0x40
Standard = CCITT
Channel ID i = 0x83
5d23h: ISDN BR0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xC0
Channel ID i = 0x89....
Success rate is 0 percent (0/5)
TIGER#
5d23h: ISDN BR0 Q931: RX <- DISCONNECT pd = 8 callref = 0xC0
Facility i = 0x91A11A02021A4E0201233011300FA10D810346522EA20681010082010
5d23h: ISDN BR0 Q931: TX -> RELEASE pd = 8 callref = 0x40
5d23h: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xC0
can somebody help
Ali
1 REPLY
Re: Urgent help needed : DIALUP Connection to Australia
Its a telco issue. You can see the cause "Unallocated/unassigned number" which means telco can't route the call to destination based on the number dialed. So verify with local telco to see the number dialed 0061260567934 is correct. May be the format is wrong.
204
