06-08-2006 02:33 AM - edited 03-03-2019 03:33 AM
We need to install Catalyst 4000 Family Power Entry Module (PEM). Do we need to power down the switch?
Is it hot pluggable?
Thanks in advance
06-08-2006 02:50 AM
hi
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/cn11189.htm
in this link they have mension in caution to remove the external power before installation...
may this helps you
rate the post if it helps
regards
Devang
06-08-2006 07:41 AM
It says 'Ensure that the external power supply is disconnected from the power source before you install and connect it to the PEM.'
It seems to be we need to disconnect the external power for the PEM only. Do we need to disconnect the existing AC connections? i.e. do we need to shut down the switch?
06-08-2006 08:28 AM
NO, you need to make sure that the PEM is disconnected from external power, you do not need to power down the three other PS in the chassis.
Please rate helpful post.
