urgent urgent problem ON MY 6509!
i have updated the 6509 sup1-2GE from the hybrid IOS TO Native IOS(I RELOADED THE SWITCH MANY TIME).EVERY Thing was fine,today i have restartED the switch it goes to romon"System Bootstrap, Version 5.3(1)
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
rommon 1 >
rommon 1 >.
NOW;when i enter the command boot slot:c6sup11-dsv-mz.121-20.E2.the 6509 starting normaly.what is the problem now how can i fix it;i dont need every time to boot manuly.
have a look to show bootvar:Router#show bootvar
BOOT variable = slot0:c6sup11-dsv-mz.121-20.E2,1
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c6msfc-boot-mz.121-3a.E7.bin
my IOS ON SLOT0:64M"c6sup11-dsv-mz.121-20.E2"PLS HELP ME TO SOLVE THIS PROBLEM
  • Other Network Infrastructure Subjects
Re: urgent urgent problem ON MY 6509!
When the switch is booted, can you post the following:
show boot
dir bootflash:
show run | inc boot
It may also be helpful to have a console output of the failing boot process.
thanks,
Bobby
Purple
The register is correct for the RP but my guess is the register on switch processor side is incorrect . At the rommon prompt see if you see what the register is , it is in the switch processor at this point .
Thats my suspicion as well.
Purple
To check on the switch procesor side do a "remote login switch" command and this will take you to the switch processor , do a show version at that point . Register should read 0x2102 , if not it needs to be changed.
10xs for ur reply!
i was set the registry on sp to 0x2102 when i have converted the box.ps have a look to the skow output:
Router#remote login switch
Cannot remote to switch
Router#show boot
Standby is not up
Router#dir bootflash:
Directory of bootflash:/
2 -rw- 5118776 Jan 1 2000 00:10:47 +00:00 c6msfc-is-mz.120-7.XE1
3 -rw- 1665640 Feb 14 2000 21:51:26 +00:00 c6msfc-boot-mz.121-3a.E7
4 -rw- 6138572 Feb 14 2000 21:52:25 +00:00 c6msfc-ds-mz.121-3a.E7
5 -rw- 17619 May 16 2004 19:08:40 +00:00 startup-configr
15990784 bytes total (1442752 bytes free)
Router#show run | include boot
boot system flash slot0:c6sup11-dsv-mz.121-20.E2
boot bootldr bootflash:c6msfc-boot-mz.121-3a.E7
Hi!
in the 1st 6509 i can't do "remote login switch" but in the 2ndi DID The register its 0x2100.how can i change it to 0x2102.
B/W When i issue remote login switch in be at this point/swuitch-sup#
10xs
Ali
Hi friend!
10xs for ur help.the problem has been solved.
10xs veru much
Ali
291
