04-05-2006 01:27 AM - edited 03-03-2019 02:39 AM
hi,
there is option to specify default gateway on switch.
what is the purpose of it?
skrao
04-05-2006 01:35 AM
Layer 2 switches have to be configured like IP hosts, which are not capable of routing. In the same manner that you assign default gateways to hosts, you need to assign a default gateway to such a L2 switch so that management traffic from the switch can be routed to the gateway router.
Pls do remember to rate posts.
Paresh
04-05-2006 01:36 AM
another solution is enable proxy-arp on gateway.
04-05-2006 03:20 AM
You can use proxy but it security best practice to not use it if you don't need to.
