Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
use of default gateway on switch
hi,
there is option to specify default gateway on switch.
what is the purpose of it?
skrao
Purple
Re: use of default gateway on switch
Layer 2 switches have to be configured like IP hosts, which are not capable of routing. In the same manner that you assign default gateways to hosts, you need to assign a default gateway to such a L2 switch so that management traffic from the switch can be routed to the gateway router.
Pls do remember to rate posts.
Paresh
another solution is enable proxy-arp on gateway.
Purple
You can use proxy but it security best practice to not use it if you don't need to.
238
