Community Member
using a 3550 switch as default gateway - conf included. is this ok?
Ok - we just setup a 3550 switch to be our default router and I need some advice as to if i set it up correctly or any gotcha's that i may have missed:
as you can see i have the 4 subnets. i do not have a route configured to the other 3 subnet ports - I wasn't sure if the box handled that or if I need to add a static route - what i mean is if client 1.1.1.2 needs to get to 1.1.2.3, do i need to add a route to fast/ethernet2? does this config look ok and are there any issues that i may encounter with this type of configuration? thanks for any info. (newbie - still learning :))
config:
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router
enable secret 5 xxxx
enable password 7 xxxxx
ip subnet-zero
ip routing
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no switchport
ip address 1.1.2.1 255.255.255.0
interface FastEthernet0/3
no switchport
ip address 1.1.3.1 255.255.255.0
interface FastEthernet0/4
no switchport
ip address 1.1.4.1 255.255.255.0
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 1.1.1.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.27.52.213
ip route x.x.x.x x.x.x.x x.x.x.x
ip route x.x.x.xx.x.x.x x.x.x.x
ip http server
line con 0
line vty 0 4
password 7 xxxx
login
line vty 5 15
password 7 xxxx
login
end
(numbers changed to protect the innocent.)
Re: using a 3550 switch as default gateway - conf included. is t
You do not need top configure anything to route from one interface to another on the SAME 3550/router
Community Member
Ok great. I wasn't sure. Is this config look ok? Any issues that may arise that i haven't configured for?
Community Member
ok, i enabled two ports and i can't get to the network on teh 2nd port. what am i doing wrong? :(
Community Member
u might have to enable ip routing. seems its turned off by default.
Community Member
IP routing is enabled.
Community Member
Ok, I have more information. it appears that it does work but very flaky. ping timeouts etc. router moves very slow. ios is 12.1 - i am going to update the ios and see if that helps. also, i have 65526k/8192k bytes of memory. maybe this isn't enough?
236
