Webcast-Catalyst9k
Using C2621 to access FTTH, PPPoE over Ethernet, NAT..
My IOS version is IP PLUS IPSEC 56 12.2-11.T2, and I found I can connect to the internet by while accessing certain website. It get stuck and sometimes it needs more mouse clicks to get that page...and some urls are smoothly as usual...here is my config.
ip name-server
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp excluded-address 192.168.2.200 192.168.2.254
ip dhcp pool TOKYO
network 192.168.2.0 255.255.255.0
netbios-node-type h-node
default-router 192.168.0.254
dns-server 203.216.70.70
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
voice call carrier capacity active
mta receive maximum-recipients 0
interface FastEthernet0/0
no ip address
speed auto
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1
ip address 192.168.2.254 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface Dialer1
ip address 202.215.15.102 255.255.255.248
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname gf00000000000000@b-fam.svips.gol.com
ppp chap password 7
ip nat inside source list 100 interface Dialer1 overload
ip nat inside source static 192.168.2.253 202.215.15.101
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
any misconfiguration ??
1 REPLY
Re: Using C2621 to access FTTH, PPPoE over Ethernet, NAT..
It will be a MTU problem..Use following command under the fastethernet interface
ip tcp adjust-mss 1452
Here is the PPPoE troubleshooting guide for that issue. Its same for all the PPPoE suppoting routers as cpe.
http://www.cisco.com/warp/public/794/827guide_pppoe827_ts.shtml
It also discuss same issue..Pl. focus on section
"Why can I access some web pages with PPPoE but not others?"
Here is the url for more mtu tunning information
http://www.cisco.com/warp/public/471/l2tp_mtu_tuning.html
460
