Community Member
Using Gig Port on Sup720
I am attempting to use the gig ports on my sup 720's to uplink two 7600's. I have tried crossover cables and straight cables and neither works. I can get a link light on other ports with the same cable, and the ports are not admin-down. What am I missing?
Matt
1 REPLY
Gold
Re: Using Gig Port on Sup720
What are you trying to uplink to? Some non-Cisco devices don't smoothly connect to Cisco Gigabit Ethernet interfaces, the fix is usually to change some settings on the Cisco side.
214
