Using ISDN TA for dialling to AS5300
we have a NAS setup comprising of AS5300 and PRI links grouped into a hunting group. Currently all the dialin users are V.90 modem users using PSTN to log into the NAS after getting authenticated by the AAA server. Now we have requirement to add ISDN dialin users to the existing NAS network. I am not very sure how we can setup connectivity for these ISDN users using TA.
I have gone thru the site
http://www.cisco.com/warp/public/129/28.shtml#config_opts ...
but here it mentions to remove AAA auth which i cannot do as my existing modem users will be affected.
Can anyone provide a config which will allow the existance of both analog modem users and ISDN TA users. (AAA is a must).
Re: Using ISDN TA for dialling to AS5300
You need to configure your controller to support ISDN PRI.You can use the following configs as templates for both analog & ISDN users.
However, I'm not sure how you want the user authentication to be. If you want to allow same user name/password to access ISDN service no problem, just go ahead; no nas port entries are required at you authentication server. Otherwise you should have NAS PORT entries at your authentication server to identify the Analog/ISDN users.
If you post your aaa configuration we could proceed further.
Regds,
Dinesh.K
isdn switch-type primary-net5
controller e1 1/0/11
pri-group time-slots 1-31
interface serial 1/0/11:15
ip unnumbered Loopback0
encapsulation ppp
ip tcp header-compression passive
dialer-group 1
isdn incoming-voice modem
peer default ip address pool DIALPOOL
ppp authentication pap chap
ppp multilink
dialer-list 1 protocol ip permit
The config is pasted below. As mentioned earlier we use AAA server for authentication. Iam looking at the option of using the same username/password for both analog and isdn access. The call gets connected (authentication succeeds) at 64K with the current setup itself when I use the ISDN TA and an IP is assigned but howvever IP doesn't flow. (On the NAS it shows as a sync user connnected.
I think we may need to use the vty interfaces....
CONFIG below
aaa authentication login SECURE group radius enable
aaa authentication login CONSOLE local enable
aaa authentication login AUX local enable
aaa authentication login VTY local enable
aaa authentication ppp default if-needed group radius local
aaa authorization network default group radius
aaa authorization configuration default group radius
aaa accounting send stop-record authentication failure
aaa accounting update newinfo
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
controller E1 0
framing NO-CRC4
clock source line primary
pri-group timeslots 1-31
interface Serial0:15
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn incoming-voice modem 64
no fair-queue
nterface Group-Async1
ip access-group 100 in
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer-group 1
async dynamic routing
async mode interactive
peer default ip address pool pool0
no cdp enable
ppp authentication chap pap
group-range 1 200
interface Dialer1
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer-group 1
no fair-queue
ppp authentication chap pap pool0
ppp multilink
kvrmurty
I guess you missed the "dialer-list" in your configuration, check out that. More often this is the root cause for the problem you said.
And can you clarify why do you need Dialer Interface, your requirements can be satisfied without dialer interface with the configuration that given earlier.
Can you post "debug ppp neg" output for a particular call.
If you need more assistance let me know.
87
