Using Link Compression (STAC) in conjunction with WFQ
I have a 128K kilostream which is suffering from conjestion caused by bursty traffic. The link currently uses compression and I'm considering using WFQing. I seem to recall reading something about issues when using queuing in conjunction with link compression but cannot find any info on this at present. Can anyone let me know if it is safe to use these together?
Rhodri
1 REPLY
Bronze
Re: Using Link Compression (STAC) in conjunction with WFQ
There was a bug with early 12.0 code with WFQ and compression on a 3640... CSCdk45866. This bug has been resolved in 12.0(2.1) or higher, so this should not affect you any.
Here is a link to the bug toolkit if you would like to view the details on the resolved bug:
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
75
