07-02-2002 05:04 AM - edited 03-01-2019 11:19 PM
Hi all,
Just a quick question. Apart from using Hyper Terminal came with MS operating systems to connect to Cisco routers, any good terminal programs that can be used on RedHat Linux to connect to router console port? I tried some searches on Google but I can't find any good terminal programs on RedHat Linux.
Thanks in advanced
07-02-2002 05:21 AM
Try Minicom
07-02-2002 06:02 AM
You might also try "tip" . This comes with most flavors of unix.
Hope this helps,
Don
07-03-2002 05:17 AM
Thanks to both donewald and prkrishn :)
donewald,
I tried to launch "tip" from RedHat, unfortunately there is no such command. Maybe you are right that the "tip" command is for Unix systems. I will see if I can get a Solaris box to work with Cisco routers.
prkrishn ,
I found "minicom" in my Redhat systems, I will try to configure it to get it works.
Once again, thanks to both of you :)
