Using NAT during Network Transition
We are planning to replace a few servers within our network, and I am trying to configure our Catalyst 6009 to use NAT to translate the target IP address to the IP addresses to the new servers. But I also need to be able to connect to the new servers directly.
I have installed a PC on vlan 24, the original server on vlan 50 (172.30.50.230) and the new server on vlan 51(172.30.51.230).
With the configuration shown below, when I telnet from the PC to the old server (172.30.50.230) I get connected to the new server (172.30.51.230) as expected.
The problem is that I cannot telnet directly into the new server (172.30.51.230), although ping and traceroute go through to the correct destination.
Is there another command line I need to enter to enable NAT to accomplish this or is there another method I could use instead?
I know I am missing something really simple, so if someone could let me know, that would be really helpful.
interface vlan 24
ip nat outside
interface vlan 50
ip nat outside
interface vlan 51
ip nat inside
exit
ip nat inside source static 172.30.51.230 172.30.50.230
TIA
Dean Scrim
Comms Engineer
Re: Using NAT during Network Transition
This is very complicated process - it involves thorought knowledge of the network topology. Call me so I could discribed to you more...
router1#
Loopback45
ip add xxx.xxx.xxx.xxx mask xxx.xxx.xxx.xxx
inter vlan???
ip policy route-map nonat???
ip nat in or outside
access-lists 145 permit ip xxx.xxx.xxx.xxx 0.0.0.xxx host xxx.xxx.xxx.xxx
access-lists 146 permit ip xxx.xxx.xxx.xxx 0.0.0.xxx host xxx.xxx.xxx.xxx
ip nat in/outside source static xxx.xxx.xxx.xxx 0.0.0.xxx extendable,
route-map nonat1 permit 10
match ip address 145
set interface Loopback45
router2# you will go to the same some similar process or the opposites informations.
it will solve your issues like magic!!!
the router is confused with less info you providing - this will explecitely tell the router(s) what to do with the packets...
Layer3(msfc) blade only!!!
IOS MSFC Software (C6MSFC-JS-M), Version 12.1(4)E1 or above.
-Benjie203.317.5132
Benjie,
Thanks for the tip, I have been trying to configure the routers as you suggested but I have not had to set up access-lists before so this is all new to me.
In the line
should I use
access-lists 145 permit ip 172.30.50.0 0.0.0.255 host 172.30.51.230
We are using Cisco Internetwork Operating System Software
IOS (tm) MSFC2 Software (C6MSFC2-IS-M), Version 12.1(2)E
TIA
Dean
Dean:
It should work...The host resides in the same segment with this router interface, correct? If then, try that.
Have fun :-)
-Benjie
111
