Using NAT with Interface Virtual-Template
ovieira
Hi!
I'm trying to use NAT to a Virtual-Template interface (see the example). It doesn't work (the virtual-template is also down-down). Where seems to be the problem?
hostname Router
ip cef
multilink virtual-template 1
controller E1 0/0
channel-group 1 timeslots 1-31
controller E1 0/1
controller E1 1/0
controller E1 1/1
interface Serial0/0:1
ip unnumbered Virtual-Template1
ip nat outside
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
interface Serial0/1:1
ip nat outside
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
interface FastEthernet1/0
ip address 10.10.0.9 255.255.0.0
ip nat inside
interface Serial1/0:1
ip nat outside
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
interface Serial1/1:1
ip nat outside
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
interface Virtual-Template1
ip address 62.48.193.242 255.255.255.252
ip accounting output-packets
ip nat outside
ppp multilink
no ppp multilink fragmentation
ip nat inside source list 69 interface Virtual-Template1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 62.48.193.241
access-list 69 permit 10.10.0.0 0.0.255.255
raymong
Level 4
Level 4
NAT will not work if the interface you are overloading to is not in an up/up status. Under your serial interfaces, you have keepalives turned off... be sure that those serial lines are actually up and that traffic can traverse those links.
Hi!
I solved the problem using a loopback and configuring "ip unnumbered" in the Virtual-template interface. About your question: traffic does go trough the serial interfaces but the NAT traffic. The problem was that the Virtual-template interface is always down/down and, as you say, we can't do NAT with that kind of interface.
Thanks for your answer,
Olindo
