Using of virtual-access interface as backup
admin_2
Level 3
Level 3
I want to use ISDN for backing up my
serial-line in case of heavy load
(backup-load) or backup the serial line if it fails. If Backup-interface is open traffic should be load-balanced
between Serial-line (2Mb) and dialer interface (consisting of some B-channels, up to 30) depending on how many channels of backup interface are open.
Unfortunately the bandwidth(or any other metric) are not changing depending on the count of open channels,
so I used a virtual-template to create a
virtual-access-interface which changes the bandwidth metric depending on the open B-channels.
All works fine, until the serial-line comes back (or falls under the configured backup-load) Now the virtual-access interface should be kicked off, but only the dialer-inertface or the virtual-template interface(does not matter which of the two we configured as backup-interface) is kicked off and the virtual access interface is unfortunately remain up and running.
Any trick known to prevent this behaviour
Not applicable
To do this, you need the fix for
CSCdm79383, 12.1 and later. Your config
should look like this:
interface Serial1
no ip address
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 10
dialer leased <-----New Command
ppp authentication chap
ppp multilink
interface Serial0:23
no ip address
encapsulation ppp
dialer pool-member 10 max-link 2
ppp multilink
interface Dialer10
ip unnumbered Loopback0
encapsulation ppp
dialer remote-name HQ
dialer pool 10
dialer disable-multiencaps <---New Command
dialer string 202
dialer load-threshold 5 outbound
dialer-group 1
ppp multilink
ppp timeout multilink link remov
