Webcast-Catalyst9k
Using of virtual-access interface as backup
I want to use ISDN for backing up my
serial-line in case of heavy load
(backup-load) or backup the serial line if it fails. If Backup-interface is open traffic should be load-balanced
between Serial-line (2Mb) and dialer interface (consisting of some B-channels, up to 30) depending on how many channels of backup interface are open.
Unfortunately the bandwidth(or any other metric) are not changing depending on the count of open channels,
so I used a virtual-template to create a
virtual-access-interface which changes the bandwidth metric depending on the open B-channels.
All works fine, until the serial-line comes back (or falls under the configured backup-load) Now the virtual-access interface should be kicked off, but only the dialer-inertface or the virtual-template interface(does not matter which of the two we configured as backup-interface) is kicked off and the virtual access interface is unfortunately remain up and running.
Any trick known to prevent this behaviour
1 REPLY
Anonymous
N/A
Re: Using of virtual-access interface as backup
To do this, you need the fix for
CSCdm79383, 12.1 and later. Your config
should look like this:
interface Serial1
no ip address
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 10
dialer leased <-----New Command
ppp authentication chap
ppp multilink
interface Serial0:23
no ip address
encapsulation ppp
dialer pool-member 10 max-link 2
ppp multilink
interface Dialer10
ip unnumbered Loopback0
encapsulation ppp
dialer remote-name HQ
dialer pool 10
dialer disable-multiencaps <---New Command
dialer string 202
dialer load-threshold 5 outbound
dialer-group 1
ppp multilink
ppp timeout multilink link remov
91
