Community Member
using same subnet on 3640
Looking for advise or documentation on setting up same subnets on 3640. Trying to set-up remote IP telephone service through 3640, having problems. Talked to maufacture and got propoer set-up. But still having problems with what they say is port forwarding. trying to set up the server with public IP and open proper ports. Having the problem with the router.
Community Member
Re: using same subnet on 3640
Below is a link with information on IP Addressing and Subnetting for New Users
http://www.cisco.com/en/US/partner/tech/tk365/tk554/technologies_tech_note09186a00800a67f5.shtml
The following are useful links to IP subnetting tools.
http://www.cisco.com/cgi-bin/Support/IpSubnet/home.pl
regards
Community Member
You need to enable bridging to use 2 same subnets on the router. It can either be normal bridging, irb or crb.
397
