Using Single host in NAT Pool and Static NAT Configuration
Can the same host address (148.92.24.206) be used in NAT Pool and Static NAT configuration?
Router-configuration
interface FastEthernet0/0
description 100MB LAN
ip address 148.92.158.189 255.255.255.0
ip nat inside
interface Serial0/0.100 point-to-point
description PVC to Santa Clara, CA
ip address 10.25.16.66 255.255.255.252
ip nat outside
frame-relay interface-dlci 100
ip nat inside source static 148.92.24.206 148.92.165.129
ip nat pool hide_routes 148.92.164.145 148.92.164.145 netmask 255.255.255.0
ip nat inside source list 2 pool hide_routes overload
access-list 2 permit 148.92.24.0 0.0.0.255
Re: Using Single host in NAT Pool and Static NAT Configuration
This typically such a cinfiguration where people are making it difficult for themselves, and others.
The adress mentioned causes a match on access-list 2. This could cause unpredictable results. I don't know what takes precendence in this case. I would do the following:
Try to exclude this specific address from the acces-list.
no access-list 2
access-list 2 deny 148.92.24.206 255.255.255.255
Now you can check your NAT process by observing the hits on the second line using the sh access-list command. In this manner you can test and tune your configuration.
Goodluck!
On the way home, I realized that the given mask was wrong.
It should be:
The other one would match anything to be denied.
Hope you still get the point !
Thanks for your assistance. I got the point and your approach works.
132
