Webcast-Catalyst9k
Using SNMP to retrieve configuration from Cat 2950
Since writeNet OID doesn't appear to work for Cat 2950, is there another way to
retrieve the configuration using SNMP? Other OID strings mentioned in TAC don't
seem to work either.
Blue
Re: Using SNMP to retrieve configuration from Cat 2950
Have you looked at: http://www.cisco.com/warp/public/477/SNMP/11_7910.shtml ?. Since Cat2950 does not support CISCO-CONFIG-COPY-MIB, therefore can't use http://www.cisco.com/warp/public/477/SNMP/copy_configs_snmp.shtml.
I was wrong. Actually it does work with the writeNet OID. Unlike the 35xx-XLs, it just
doesn't send a snmp reply to the snmp set command.
300
