06-23-2003 12:59 PM - edited 03-02-2019 08:21 AM
I have got SSH and use it to connect to our Linux machine. I want to use it to remotely connect to our routers instead of using Telnet, which I think is not so secure.
How do I configure the router for SSH log in. I have notice that the transport input available are telnet, all, lapb-ta, none, pad, rlogin, v120
need your help
06-23-2003 02:10 PM
you need a crypto version that supports ssh , you should see transport input ssh when you put this version
after upgrading the router to a crypto version(des/3des) then go to this link
to configure it
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/fothersf/scfssh.htm
guy
06-24-2003 09:13 AM
It sounds like the IOS on the routers does not support secure shell. Use this link to find out which IOS supports SSH and "Search by Features"...
http://www.cisco.com/cgi-bin/Support/CompNav/Index.pl?Introduction=True
06-26-2003 12:37 PM
I did log into this site and with the type of Internet connection I got, I got a hard time trying to locate it . Anyway, can you just give me in simple terms what IOS I will need. Also the recommended IOS should support SNMP Version 2 or 3.
Like IOS ver 2.2 with what feature
regards
06-27-2003 12:04 PM
Need to know what kind of Cisco routers you have, how much flash memory you have, and how much DRAM you have on each router.
