Using SSH to remote connect to routers
I have got SSH and use it to connect to our Linux machine. I want to use it to remotely connect to our routers instead of using Telnet, which I think is not so secure.
How do I configure the router for SSH log in. I have notice that the transport input available are telnet, all, lapb-ta, none, pad, rlogin, v120
need your help
Re: Using SSH to remote connect to routers
you need a crypto version that supports ssh , you should see transport input ssh when you put this version
after upgrading the router to a crypto version(des/3des) then go to this link
to configure it
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/fothersf/scfssh.htm
guy
It sounds like the IOS on the routers does not support secure shell. Use this link to find out which IOS supports SSH and "Search by Features"...
http://www.cisco.com/cgi-bin/Support/CompNav/Index.pl?Introduction=True
I did log into this site and with the type of Internet connection I got, I got a hard time trying to locate it . Anyway, can you just give me in simple terms what IOS I will need. Also the recommended IOS should support SNMP Version 2 or 3.
Like IOS ver 2.2 with what feature
regards
Need to know what kind of Cisco routers you have, how much flash memory you have, and how much DRAM you have on each router.
937
