09-23-2002 05:32 AM - edited 03-02-2019 01:33 AM
How can I setup a static route to be a backup in case of a failure on an IGRP route. Attempting to add the static route with a higher metric results in nothing being added to the routing table.
Solved! Go to Solution.
09-23-2002 06:08 AM
adding a static route with higher AD works fine. You could not see it in routing table if major route active. When it fails the backup route will be active and be added to the table automatically.
09-23-2002 06:35 AM
You could test this with a more specific route if you would like to just test your backup path.
Lets say you have a 192.168.3.0/24 route that IGRP has in it's routing table with a next hop of your primary link. If you make your static for just 1 host "ip route 192.168.3.200 255.255.255.255
Hope this helps,
Don
09-23-2002 05:57 AM
IGRP's Administrative Distance is 100 so if you are putting in a static with a higher distance you will not see it in your routing table until your IGRP route goes away for that destination. Make your IGRP route go away for your destination and you should then see your higher cost static in your routing table.
Hope this helps,
Don
09-23-2002 06:00 AM
That help sort of. The problem is I want both the IGRP and the higher value static route to co-exist. If the IGRP route goes down it should then use the static route.
How woulf this me possible
09-23-2002 06:03 AM
AM I not understanding this correctly. The static route is still there but not shown until the IGRP route is down? Is it therefore possible to bring down the IGRP route to test this?
09-23-2002 06:18 AM
Absolutely. Route entry with higher AD is not shown due to routing policies. If IGRP route is down then static become active and takes control. I recommend you not to check it because I use the same way for backup purposes.
09-23-2002 06:35 AM
Hope this helps,
Don
09-23-2002 06:08 AM
