09-21-2006 09:19 AM - edited 03-03-2019 05:10 AM
Are there instances when you would not use STP? Why would you not want to run STP?
09-21-2006 11:35 AM
STP is used to prevent loops in layer 2 networks.
U can disable STP in u r network if ur not having any redundant links between u r switches.But it is not recommended to disable STP.
Mahmood
09-21-2006 03:23 PM
why dont u want to use STP ? is it because convergence time?if so there many config that u can reduce the convergence time...
