Webcast-Catalyst9k
using the 60 Pin DTE/DCE Cable, can you connect a 2500 Router and a 1601 for a lab? DO both have to have the same IOS?
I want to set up a lab enviroment. I have a spare 2500 router and a 1601. Using the 60 Pin DTE/DCE, can I connect them via the serial interfaces? Do both have to have the same IOS?
1 REPLY
Anonymous
N/A
Re: using the 60 Pin DTE/DCE Cable, can you connect a 2500 Route
Yes, they can be connected back to back. One interface as DTE (default) and the other one as DCE (use clockrate command within the interface), most of the time it is recommended to run the same IOS release
111
