using variables
Is there a way to use variables in IOS? For instance, I want to tftp the same file from several switches to my server and I would like the destination filename to be the same as the hostname. So, is there a way to reference the variable containing the hostname?
1 REPLY
Re: using variables
There is an ip to host name mapping table that you can create on the router and then refer to the name rather than ip address. I am not sure if this answers your question.
ip host r1 1.1.1.1
ip host r2 2.2.2.2
89
