Community Member
Using Vlan's on a Cisco 2610XM with 16 Ether switch module
I am planning to use a 2610XM with a 16 10/100 EtherSwitch module. I want to allocate Vlan's to the Etherswitch ports but transmit the Vlans over the TCP/IP or Bridged interface on the 2610 router. This link will terminate on another router and then reverse the process to output the separate Vlan's.
How can I do this?, I have done this when using physical interfaces (separate Switch & Router) but not when the switch and router are combined?
Anyone have any pointers?
ABurtchaell@ipwireless.com
1 REPLY
Bronze
Re: Using Vlan's on a Cisco 2610XM with 16 Ether switch module
The configuration part will be similar to that of a switch like Catalyst 3550 which can function as a layer2 or layer3 device , except for the interface numbering. Check this one :
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12119ea1/3550scg/index.htm
132
