Using wic-1am for Dial-backup
This is probably a newbie question but I haven't been able to find any configuration samples.
I have a small site that is using a partial T1 for internet connection. I need to setup a backup connection for when that goes down. I have an extra wic-1am here and would like to use in this 2600.
I will need the backup to connect to an ISP with one of our accounts (only need the internet connection). Is this something simple to do? The company will not spend the extra for a DSl/ISDN line.
Thanks!
1 REPLY
Re: Using wic-1am for Dial-backup
It should be easy to configure dial backup using wic-1am. Here is the link for that
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xb/122xb_2/ft12pwic.htm
WIC-1AM is a analog modem so configuration wise its same as other analog modem. So you can visit following url for more specific backup config for serrial line using analog modem
http://www.cisco.com/warp/public/793/access_dial/async_backup_dp.html
155
