UTC: %FIB-4-RPPREFIXINCONST2 error message
I'm getting following message on CISCO 75000 router. Any one can help me to resolving issue.
UTC: %FIB-4-RPPREFIXINCONST2: RP missing prefix for 192.168.31.16/30 in FIB table Default-table (present in routing table)
1 REPLY
Re: UTC: %FIB-4-RPPREFIXINCONST2 error message
Looks like you have problem with the cef table entries.
The error message %FIB-4-RPPREFIXINCONST2 conveys , that a passive consistency checker discovered a prefix in the routing table that is not present in the CEF forwarding table
on the RP. This may be a transient condition.
If the same prefix gives repeated errors, check the prefix in CEF and the routing table. Attempt to disable
and enable CEF if the prefix is missing.
Please refer the flg. link for CEF troubleshooting http://www.cisco.com/warp/public/63/cef_error_msgs_7603.shtml#rpprefix
Hope this helps...
103
